Hi All !
Just having a bit of a play around and did the following clock mod ! i removed the original one and replaced it with the one in the pics, i had a spare centre dash section so did'nt care if it went pete tong ! in fact i am so please with it its staying in the car !!
The clock has display for time, alarm, just in case !! inside and outside temp, when i switch on the lights the back light in the clock also comes on like the original one, now just working on a auto dimmer for it ! i linked it all in to the original clock wiring using small brass plates to slide into the plug assembly, next project is to fit my volt and oil temp digital meters into the two airvents in the middle which should be a piece of cake !
