1 - 12 of 12 Posts
jl audio set up.. subs, components amps ect ect.
or
fusion set up.. subs, components amps head unit ect ect?
help me.
Arg torn a bit here mate!
Just ordered some nice JL Audio components (£300 worth very very very nice)
However I hear Fusion stuff is v good for the cash!
Go for Fusion amps and JL Audio Sub and comps!
Or if it has to be all the same go for .........
Genesis :))
The only question I can think of is:
Green and White or Silver and Black
Personaly I would have the JL but I think the lower level subs look a bit cheap
R6 Owner
I had a similar problem a while ago.
Fusion in bomb proof
Jl is well Jl
Needless to say i went with the latter.
Muz which components you got pal?
gonna wait to see what kabash's sounds like at guildford meet then make my mind up then, he has fusion subs amp.
Maddsy said:
muz said:
Maddsy I just bought these babies http://www.caraudiodirect.co.uk/product_info.php?products_id=405
Wanted DLS ultimates but canny get them second hand anywhere!
Muz - they are the same as mine.
I think they are the dogs doo dahs for not a lot of money :up:
I just get worried when companies write "audiophille" in the product description..... however they are bought, just need to get them in the post then...
sound deadon the doors build the sub box, fit the amps and the LEDs build the amp surrounds, sound deadon the boot, run all the cables drill a huge hole in my bulkhead (Gulp) position the tweeters a 1000 times then realise I can't fit them where they sound best, buy an invertor fit the ps2 buy a screen, fit it, pray I can make the sound come through the system get it all set up then actually listen to a cd in the car!
Taking a week off work to do it! :bash: :wman: :wman: :wman: :wman: :wman: :wman: :wman:
muz said:
http://www.talkaudio.co.uk/classifieds/showproduct.php?product=968&sort=1&cat=5&page=2
I take it? £500 for actives but £900 for passive!! (However still very cheap if only :p
Only paid £160 for the JLs
Do you think I would blow £900 sheets on a passive set? Not got enough power to go active only 2x 120 RMS
dont need power runnin active! neway even if u did need a bit more only a new amp needed
1 - 12 of 12 Posts
