1 - 12 of 12 Posts
hi, for a few weeks now my rear passenger side wheel has been making a really loud squealing noise when i go round a sharpish left hand bend. as soon as i straighten up it stops!
it sounds like 2 bits of metal rubbing together to make a loud squealing noise.
i would have thought it would have been the opposite but it only does it going round a left hand bend when the weight is on the drivers side.
please help :)
Hi, im currently having the same problem with my front left wheel and cant be sure whether is the disc and brake rubbing together or a wheel bearing problem, can anyopne help that has experience with this?
or even know what it is?
In my experience its one of two things.
A piece of gravel stuck between the the disc back plate/disc/caliper
or more likely the pad wear indicators, mine did it on cornering and on inspection my pads had reached their limit
I have drums but my squeeling is from the front left. would they both not squeel if its break bad wear? I might take a look at the pads then mate! cheers.
Formerly Trophynovabasher
brake pad wear me tinks
Had the same thing for a couple of days, and already had some pads ordered, when I took the calipers off there was literally none of my EBC Greenstuff left! After I rpelaced the pads the issue stopped, just caught the pads in time before they ruined the discs with horrible score marks.
1 - 12 of 12 Posts
