Would be interesting to see how light the ZR can get.All the back is stripped out and ive got no door cards. Will give it a weigh tommorow if your intrested? 10kg can be had from removing the soundproofing on the floor as well. That stuff weighs loads! Shame its a biatch to get off...
Does the drive feel any different with reduced weight? does you feel any improved performance?Went for a drive in it today, you can really hear the fuelpump going without any carpets which is quite off putting, as well as stones and other stuff rattling as it bounces under the car.
Doesnt do much for the refinement. Its also raised the back of my car, bit higher at the back than the front now![]()
if you remove 100kg you will feel a massive difference. Acceleration will be vastly improved. This is the good part.Does the drive feel any different with reduced weight? does you feel any improved performance?
Felt faster, but before I had a 1.4 with an interior, and now ive got a 1.8 with no interior. So I cant really say what its done to be honest. I can brake later though and take a few corners a little faster, so it has made a difference!Does the drive feel any different with reduced weight? does you feel any improved performance?
And that was just your gimp suit !!I took 66kg out of mine...every night when I parked it up![]()
with you in it...And that was just your gimp suit !!![]()
I never really thought of the weight of people effecting the car. Mine must be mega slow cause i weigh just under 100kgI took 66kg out of mine...every night when I parked it up![]()
Depends how hardcore you want to go... Strip the front out as well, get rid of everything. Essentially seats and a steering wheel.By the sounds of it, a stripped out ZR will weigh much the same as a ZR express...maybe see if i can get a test drive in one and see if theres much difference
Nothing I don't experience in normal day to day driving.as the rattles and general noise would get to me big style.
