VTEC addict
Had my head gasket changed about 2 months ago but the car feels a bit slugish and idling slightly up and down. Engine also sounds noiser
I went for an inpection under the bonnet. I held down the thorttle lever about 1/4 of the to to see where i had funny noises coming from. Pushed it to about 1/3 of the way then sundenly notice that antifreeze in the colant tank was swishing around alot. Then wen i took my hand of the thortle lever fan came on. Looked a tad frothy too!
Has the gasket been fixed right or am i getting paranoid,
Help!!
Car gone. :(
Paranoid. As long as there is no mayo/oil in the coolant tank, your alright.
VTEC addict
Nah no mayo, but should the coolant be doing that?
Car gone. :(
The coolnat moves around the engine, so when the throttle is pressed, more of the coolant moves around. I think as long as the levels in the tank are ok, you got not problems. If your not sure, just pop to the garage.
when you rev the engine, more coolent will be returned into the header tank at a faster rate than usual. Maybe why you got swirling. How was your temp guage looking while you were doing this?
Car gone. :(
Rabies?
VTEC addict
coolant hasent dropped and temp gauge is just below half.
I need to find out why my engine has become so noisey and slugish.
Engine flush?
After long runs if i turn the engine off and listen carefully i can hear all the collant rushing back into the header tank so think it couls jus be paranoia, check your spark plugs and coil pack maybe?
VTEC addict
Discussion Starter · #10 ·
is there a way to test coil packs?
