1 - 12 of 12 Posts
Discussion Starter #1
I had my tyres on my zed now for about 8k.and ive noticed the inside of the tread is wearing down more than the rest.this meaning the wheels are toeing out a bit too much...........does anyone know what the amount of toe out it should be...?and has anyone else had this........
Toe out :eek: no wonder they're wearing on the inside shoulder,i have mine toe'd in to 1 degree 30' to supposedly compensate the lowering
Discussion Starter #4
im geting it lowered next week....and got it booked it to get the tracking done.........ta
Just had my tracking done - yeah should be toeing in 1-30 as I recall. Mine was toeing OUT after the missus decided to do a U-turn in a road that wasn't wide enough :eek: :confused: Hit and mounted the kerb at 25 mpg. You can guess my reaction.
Get it adjusted soon as tyres are expensive and you can't afford to waste tread.
Discussion Starter #6
ive found out that the wheel alignment is.....
front
camber angle -0.40' +- 45'
castor angle 2deg 12'
kpi 12deg24'
toe 0deg +- 15'
rear
camber -0.20'
toe in 16'
King-pin inclination, its the angle at which is sits, but the ZR's don't have a king pin. Also it isn't adjustable as well as the castor as its part of the suspension set up, unless you go for coil overs and adjustable top mounts
Thanks Steve, I'll sleep soundly tonite now I know.
However my Kingpin us usually at an angle of 45 degrees :twisted: esp in the mornings :eek:oops:
Discussion Starter #11
just had the tracking done and the pass wheel was 2 deg toe out and the dr wheel was o deg........this mking them both 1deg toe out when driving.....causing the insides to wear down.....
now they are at 0 deg........drives lots better......
and it was free......
1 - 12 of 12 Posts
