1 - 9 of 9 Posts
Firstly...
Does anyone know the front and rear track measurements on the ZR? If so then i need, or need a link to where i could find the details...
Secondly...
Where are the engine mounts located on the T16? 1 on either side and where are the others?
Thanks chaps
John :)
Fake Bans FTW!!!
tryed rovertech?
Fake Bans FTW!!!
im bord :( so i might go an have a look for you ;)
Firstly...
Secondly...
Thanks chaps
John :)
Not sure about the 1st question, but on a 220/420 T16 theres a timing side mount that bolts to the chassis on the driverside, and a rear mount which bolts to the rear subframe. Then theres a front mount, which bolts from a stabaliser bar, to the front crossmember. The stabaliser bar, in turn, bolts to the gearbox :)
Whats your reason for asking?
If its alternative ways to mount a T16 i can give you a good bit of advice ;)
Mine is mounted using a combination of 220, K-series and diesel mounts :)
ooooooooo my head hurts after reading that lol
are you putting a t16 in a zed?
Thanks bud ;)
I think i'm sorted now matey. Thanks for help. I'll be in touch if i need further help! :D
1 - 9 of 9 Posts
