1 - 5 of 5 Posts
Right someone told me,cant remember were,the standard throttle body on the mg zr mk2 105 is restricted,is this true?
And i was looking at getting the 52mm tb,and it said easy to fit,is it easy and is it a direct fit?
no the zr had an aluminium 48mm tb, which was a lot better than the restrictive plastic one on the old 200/25, but you can put a 52mm on a 105, will give smoother acceleration and get rid of the flat spots, but dont give and poerformance boost..
its a direct fit, 4 screws iirc.. bout 30mins
right ok ,thanks for that info mate!
1 - 5 of 5 Posts
