1 - 7 of 7 Posts
"two infinitys, and beyond"
ok today im fitting this in my boot. Its the same one from my escort so i kno how to do it. But in the escort i ran the wires down the sides to the headunit and the amp wire went out through the door and wrapped round under the bonnet to the battery.
On the ZR is there a better way of doing this? like some premade holes that alot of you use that go direct from behind the dash board to the battery?
Thanks :D - Ill check back again in a few mins after i ran the cables down the sides :D
well if you looked a bit better on your escor tin passenger footwell theres a gromit and to get a cable through u just take the inner wheel arch off but thats another thing
here it is reworded:
sorry wasnt very clear before :)
i need to get the positive cable from the battery to the amp, in my escort i ran this into the wing and round the door pillar into the car. Although i dont want to do this as it isnt that safe and you can see it every time you open the door. Is there anyway of getting it through the bulk head without drilling a hole? how have you guys done it?
Thnx
o rite, well that saves drilling a new hole in the bulk head :D
1 - 7 of 7 Posts
