1 - 4 of 4 Posts
I dont know if any1 has tried this but im thinking of getting rid of my centre airvents in my car and fitting a single din motorised screen,. would it fit aswel as do the job? any 1 help with my dilemma? :wohow:
I'm nearly finished that just now. Yes it will fit, but the depth isn't enough as standard and will need you to cut away the plastic that forms the vent shaft.
Flat Capper
I think **** (with the HotWheels ZR) has already done something similar as well!
Last I tried something similar, I discovered that there is still about 15mm of the unit sticking out of the front, mostly due to the slant back of the dash, rather than it being a verticle edge.
You can, as suggested above, cut away the piping behind it - but I dont know how badly the air being pushed into audio unit, rather than into the interior will affect it. Also, once cut - there is no going back!
1 - 4 of 4 Posts
