1 - 17 of 17 Posts
When I pick up my ZR on sat is there anything like a engine managment style key
On my Honda i had a red key which was for the computer setting etc and i just wanted to make sure the ZR dont need one etc??
Is there anything else to look out for when picking it up??
thanks
Neil
ah wicked theres no worry there then its just the stock keny tape face off unit, cheers dude
Car gone. :(
Locking wheel nut key.
Make sure you have got the MFU code. This is the code that you can enter using the key in the drivers lock to override the immobilser in the event of key fob failure. Not essential but can certainly help you out if you get stuck in the rain and your key fob packs up.
There should be a card with the service book that lists the key codes, radio codes and all sorts of other codes including the VIN. It is a 4 digit code that you use to disarm the car in the event of key fob failure. The handbook explains the procedure.
1 - 17 of 17 Posts
