1 - 20 of 29 Posts
the material on my speaker cover on the left hand side its coming off so what i wanted to know is
how do you get the cover odd the door without damage the the doorcard ?
thanks
I use liquid poly - the same stuff people use on air-fix and models etc. Worked well on my floor stander speaker fabric. You do need to apply a good amount of pressure but it does dry very quickly :)
Adz
if you want to do it you need to take your door card off so you can cut the plastic bits holding it on fromt he inside, then it should pop of with a gud push. Then i used super glue to glue the fabric back to the inside of the cover and job was done ;)
1 - 20 of 29 Posts
