1 - 13 of 13 Posts
My side skirt is sagging in the middle, i was wondering if any 1 know's of a strong glue that will hold it on? + where am i able to buy it?
Cheers :beer2:
Tigerseal is the best stuff, you should find it in a big DIY store. If it holds spoilers on no worries then sideskirts will be a doddle for it :)
i use coloured silicone, or clear on other cars, holds well just need to push the kirt onto the body to hold it on while it dys, but any other tupe should be ok, just make sure you clean both surfaces before and dry them out then put enough on and pus up onto the sill and leave for a while, i used my car jack to push it up and a piece of wood jamed between the sil and the wall to make sure there was enough pressure to force them together, thing is tho, its hard to paint silicone so if its not right or you need to touch it up its hard to paint, nathan
Either tigerseal or sikaflex will do the job nicely.
Could try "no more nails" if you want, apprantly its just as strong.
1 - 13 of 13 Posts
