1 - 20 of 56 Posts
GOT OWNED BY THE LAW
im deciding weather to try and fit my coilovers by my self ?? will be next friday id do them and would have all day .. im decent with cars but its just the setting im not clued up on .. should i give it a go ??
same its just bolt on bolt off thn set up right ?
as far as im aware the fitting is easier than fitting new springs cos you dont have to mess about with spring compressors since the whole shock is being replaced.
havent got a clue about the setting up though!
if it were me with my bad luck i would screw up the car
Discussion Starter · #10 ·
lol im guna do it :p i better get it right as someone else is relying ona lift to fsm next day haha
SRS Xmas Pants On!
Actually bolting them in is easy yes, this bit you can do but you'll need the geometry setting up when they're fitted, unless you've got the £5k+ worth of equipment to set the Castor, Camber and Ride Height then up I wouldn't bother fitting them yourself.
Discussion Starter · #13 ·
see this is what i waas scared of
SRS Xmas Pants On!
Its about £100 - £200 for the geometry setting up at any decent motorsport specialist.
Your problem will be driving the car with the coilovers on until you can get it set up, you could have problems like, uneven wear on the tyres, excess wear on the tyres, wandering at any speed, severe wandering under braking etc
Personally I'd recommend saving and paying for them fitting and setting up.
hmmmmmmm i may fit thm friday for meet .. thn get them set up in the week after that should be ok ?
SRS Xmas Pants On!
Thats upto you, personally I wouldn't want to drive a car thats not got properly set up suspension, the police would have a field day if you have an accident. Wheel alignment is part of the MOT, if its not set up properly and you lose control and crash because of it, means your car isn't road worthy and insurance payout is unlikely.
alex. dont do it. not just before a long motorway trip haha. if you need to brake hard for any reason, and your car wanders...
get them done during the meet
better ride up aswell
Discussion Starter · #19 ·
good piont mate .. but rory did his and its fine ?
yeh i spose mate
yeh if i dont do them ill bring thm to the meet and if anyone cba helping me i may have a go thier
I fitted mine myself which is easy, its just what BULLIT said that its hard to set them up. Personally i would have a go myself but alow alot of time to do it because some of the bolts are really tough.
Another thing is measure them all before fitting to get them all the same height.
1 - 20 of 56 Posts
