1 - 14 of 14 Posts
i am tryin to fit my quick shift to my 105 r65 but dont have a clue where it goes and the drawing supplyed isnt much help?
i have just had a look but cant c where is is ment to go which one to i need for my 105 53 plate
I can't help, I've never fitted one or know what they look like.
Can you post a pic and I should be able to help from there
here is the pic
once you see this and see your car it will all make sense
If you go to your engine bay, look at your inlet manifold (where it says injection)
on the right handside, underneath that is the linkage
1)lift the cap off the ball joint (the small gold cap in picture) (prise it off with a flat head screw driver or something)
2)the bit the cap came off will have a ball joint, put the short shifter over this and then use that small metal piece and place it under (so it like sanwichs the bit on the car (if that makes sense!)
3)tighten up the bolts! (akward part!)
4)enjoy
1 - 14 of 14 Posts
