1 - 7 of 7 Posts
Just wondering, how often do people put oil in there ZR's? Read on another forum some guy had problems with his ZS and it was going through oil every 500miles. " failed engines later and he got rid.
The ZS was probably the KV6, some of the engines do breath quite heavily, mine does. As long as you do a weekly check on the oil level you should be fine.
Steve
mine needs toping up every 5000 ish miles. seems to use a lot of oil. when i say top up i dont mean its got nothing in, normall bout half way down
i go thru a canny bit of oil like ... but when my cars up on the ramps ive got a patch of oil on the bottom of the engine ... mechanic said it was nout tho so i aint worrying just topping the engine up.
1 - 7 of 7 Posts
