1 - 9 of 9 Posts
hiya just bought some new vibe sub speakers with 1200 watt amp it looks the dog bolocks an is very gd, but there is 1probelem there seems to a noice coming from there very time there is a slight rev, so it sounds like the speakers are revin!! if any can help that would b great!!! :up:
welcome to the site.
sounds like you need a supressor on the + to the headunit...
btw is your birthday date correct?
yeap its all correctd :cry: im only 15. but my dad bout the mgzr 160 about 6months ago an i love it so i buy alot of stuff for it e.g lights, ice kit, tints an much more... but next year im hoping to get the 105+ an hope then to do alot to it!
RIP ZR
:bash:
I herd that happens when you run the power lead along the same side of the car as all the rest of the leads ...
it makes like a whining noise.
mine does it a bit when i turn my second amp's power up.
Hey
When wiring up car dfo power lead on left, RCAs in middle and Speaker wires on
right
Also make sure you make a new earth for the amps and amp them earth them all to the same point
You will eradicate all whining doing it this way
Ive also got a vibe 1200 watt sub with an amp built in.
The problem is as follows,
When i turn on the ignition, the sub gives a load bass noise, its as it pulses for a second. I was told that its the sub getting rid of all the air from when it was last used. is this true???? and could there be a problem???
I dont have a clue about ICE so any help would be appreciated, Cheers
1 - 9 of 9 Posts
