1 - 3 of 3 Posts
I've being thinking about buying coilovers for my TD would these make much of a difference on the handling side of a TD due to the weight at the frontend.
Also can you put/get the following on a TD :
Boost controller,
Samco's,
poly brushes,
Bigger tubo intake pipe
Bigger turbo downpipe,
headwork,
pg1 gearbox.
thanks
jay
Boost controller,
Samco's,
poly brushes,
headwork,
pg1 gearbox.
thanks
jay
Coilovers are a nice option because you can adjust the heights independently.
For you list:
Boost controller is nice option as it prevents wastegate leakages
Yeah, samco are ok. There are actual silicone hose replacements that Donny Diesel had made. Donny also made a cool stainless steel turbo outlet pipe. Im not sure if it is 51mm (standard) or 57mm bore.
Headwork is not normally done to a large extent. Normally, people tend to port the inlet manifold to start with.
Uprateing the gearbox is common for cars +150 bhp, because of the torque issue. You want steel caged bearings and possibly a LSD.
yer same as above, wouldnt bother with the headwork, as you have alot more options before you get to that stage. go the derv tuners
1 - 3 of 3 Posts
