1 - 20 of 21 Posts
2.0 GT T-bar :D
same problem.. They are hard to work on to i hear, mainly cos of the size of the bay
Formerly Trophynovabasher
i have seen more Fs and TFs on the road side in a cloud of steam than i have Zrs.....
same problem and more expensive to repair due to the lack of access - takes longer, more labour.
The F/TF is more prone to problems due to the mid-mounted engine. Most HGFs are caused by coolant loss, and the F has 2 long metal coolant pipes that run the length of the car that corrode through.
They are not too difficult to get to to work on. We do most of the work with the engine in situ, including head gaskets, clutch changes, etc. Certainly a lot easier than the Lotus Elise!
hmm i suppose, but the zr and rover 25 are known for HGF but that doesnt stop all you lot going out any buying them,
anyway, if you keep on top of everything maintainence wise, theres no reason why an F couldnt be as reliable as any other mid engined car
he he, mid engined cars aren't know for their reliability tbh.
As other people have suggested, apart from the pita that is lack of space, all the cooling etc has to be elongated to the front of the car and over all the cooling is reduced.
Obviously some marques are better than others but I see high cost for little gain, working on an MR2 for example is a lot of fun :)
1 - 20 of 21 Posts
