1 - 17 of 17 Posts
Just bought a set of springs for my Mk2 ZR but cant seem to find a garage that will fit them in Falkirk :(, anyone got any recomendations or garages in the surrounding areas that would fit them?
Thanks.
Boost ftw!!
Can't you do it yourself? All you need is a set of spring clamps (halfords £10) and a socket set. That's all we needed for my old corsa. Took about an hour or so. Have to be careful the clamps don't slip though, or the spring could fly off and catch your face. That'll sting a bit!!!
Aye it might sting just a bit lol :) dont fancy trying it maself, knowin ma luck al f**k it up lol!
Boost ftw!!
Probably best if you're not sure what to do. I have a cousin that lives in stirling. You prob don't know him tho!? Ross Taylor. Has a sister Louise?
I Like To Disco Dance
thumpjunkie will do it, if not there is a garage called sounds of silence through in falkirk, Owner is called Dave just go up and he will sort you out
Na a dont know him mate, from Falkirk, put Stirling down as the location cause Falkirk aint down lol :)
Thanks mate will go down n check it out ;)
I got mine done by Progrip in Bonnybridge, just along the road from Hypertech
Thing is with lowering springs you really should get the wheel alignment done at the same time. I found my rear wheels went quite a bit out after fitting the XPower springs. Progrip has the best 4 wheel alignment system in the central belt, if not Scotland
Tell him Ross with the ZS sent you and you might even get a discount
1 - 17 of 17 Posts
