thats the way i see it too, lowering your car on avos wont make your car be able to take corners at a much higher speeds on normal road conditions because you shouldnt be taking corners at high speeds anywayheres the way i see it.
i agree that the handling being improved is MAINLY psychological (it will be improved a bit though), however, most cars are more capable than their drivers, so, when u lower it, you trust it more, and drive it harder than you normally would, therefore thinking its handling better, either way you are still going to be quicker round the track. WIN/WIN!![]()
Try explaining that to a few on hereif your car is purely a road car then avos are only really an aesthetic mod imo since you shouldnt be pushing your car to the limits on public roads anyway
what people should and shouldnt be doing isnt in question thoughtif your car is purely a road car then avos are only really an aesthetic mod imo since you shouldnt be pushing your car to the limits on public roads anyway
Try this site for some good infoAftermarket modifications and adjustments to affect handling
Main article: Racing setup
Lowering the center of gravity will always help the handling (as well as reduce the chance of roll-over). This can be done to some extent by using plastic windows (or none) and light roof, hood (bonnet) and boot (trunk) lid materials, by reducing the ground clearance, etc. Increasing the track with "reversed" wheels will have a similar effect, but remember that the wider the car the less spare room it has on the road and the farther you may have to swerve to miss an obstacle. Stiffer springs and/or shocks, both front and rear, will generally improve handling, at the expense of comfort on small bumps. Performance suspension kits are available. Light alloy (mostly aluminum or magnesium) wheels improve handling as well as ride comfort.
oh dont get me wrong, i do think it makes a difference, but whether it makes a big one or not is going to depend on how u define BIG. for example its not going to be as much of an improvement as if u fitted matched shocks at the same time etc.Sorry, but I am going to disagree. Fitting lowering springs does make a BIG difference to the handling the reason being that it stiffens the susspension. The suspension on a car is a trade off and a compromise between comfort and handling. By lowering the car you are effectively stiffening the suspension and lowering the centre of gravity (C of G). By stiffening the suspension you are reducing body roll and by reducing body roll you reduce the detrimental effect it has on suspension geometry.
This is a massive subject and also includes other factors such as dampening both on compression and rebound and spring rates. Coilovers are a good example. They were designed primarily for track use and allows the driver to dial in different spring rates (and in some cases damper settings) depending on the track and the weather condidions. Some tracks favour harder settings than others as not only does it affect handling but grip as well.
Anyway, dont take my word for it, have a look round on google. Here are a couple of sites I found
Wikipedia
http://www.torquecars.com/tuning/suspension.php
+1the way i see it is that as long as your happy with it yourself it doesnt really matter![]()
