1 - 20 of 28 Posts
What are peoples' thoughts on "LED Replacement Kits" for the dash controls? Crappy, chavvy or classy?
looks **** hot imo!
^^exactly what i want on the dials...where you get that LED kit from skelo?
Cheers Skelo, I'm all over this like a cheap suit!
I notice you have a big bright spot on your clock! I remember seeing some one on forums.mg-rover.org who has it all one gradient, i think?
I had to sod about with the standard clock in a 206 once, IIRC there was a piece of polaised plastic that did this job, might nip into a breaker's take one apart from a ZR and see how it works before mine... :sneaky:
:stupid:
When do I get the facility to edit my posts?
Should of course read "polarised"...
Since that was taken, i have almost solved the bright spot problem.
I found somebody on ebay who sells a white strip to replace the orange one, not perfect but will do for the moment.
Dave
p.s
I think it is 500 posts before you can edit them.
Dave
p.s
Quality! Can you post the seller's name?
Discussion Starter · #16 ·
You mean something like this?
Dave
Ooh, ooh, I knew there was something else. How many different kits did it take to do the whole shabang?
4 bulbs for the dials
1 in each of the switches ( i used leds with resistors for them)
1 for the clock
2 for the heater controls, but they don't work very well, so will be going to metal monkey for a kit.
Looks amazing. The bulbs are on order so you may be getting a few pm's ! lol
Thanks for the kind words, any help i can give, just ask on here, the info may help others.
Dave
1 - 20 of 28 Posts
