1 - 4 of 4 Posts
Discussion Starter #1
Hi all
can any1 tell me how to get the centre console of on my ZR. Ive undone the 4 screws at the bottom but it feels like its gonna snap off at the top where the fog light buttons are, any help is greatly appreciated. Thanks
it has 2 clips at the top.....just pull the top out slowly...then you can unplug the switches and cig lighter.
I presume you have taken the cover from around the handbrake and the leccky window switches off (if you have them)? You will need to remove the gear knob as well and the radio. If you lift from the rear, the clips will release a lot easier. Helps to put the gearstick into gear as well to clear the gaitor
1 - 4 of 4 Posts
