1 - 1 of 1 Posts
i have a 1000w amp and speakers do i need a 1000w wiring kit? the simple answer is no, the amount of power is absolutely neglegable when it comes to power cables, you can have a 10 billion watt amp and it wont make a blind bit of diffference, the only factor that effects what size power cable you need for what amp(s) is outlined in this cable chart!
the size of cable depends solely on 2 factors alone, length the current has to travel and the amperage, add together all the fuse ratings of your amps and choose a cable type, if you fall on part X you need a bigger cable
http://ebayhosting.myby.co.uk/cablechart.html
1 - 1 of 1 Posts
