1 - 9 of 9 Posts
will this plug up to a normal incar monitor and play dvds ect if so i wont one , how much for one of these to BUY NOW, i wont 1 i wont 1 i wont 1,
Hmmm....looks okay. I wouldn't personnaly go for it tho, as i would prefer to build something to the exact spec i want.
It doesn't give you an awful lot of detail about the actual machine.
Not sure what the PSU is like that it comes with. You need a suitable PSU that will allow the PC to be turned on and off with the ignition but not lose power whilst you are cranking the car. Also, it needs to be able to supply power to the PC for long ennough to enable the PC to shut-down properly when you switch the ignition off.
These kind of power supplied are about £150 so consider that before purchasing. If it comes with this, then all well and good.
It will certaily be fast enough to everythig you would want to do in the car.
Yeah should do. Will be a pain to control unless you have a touch screen tho
Im going to sell mine. I built one to put in my car, but I can’t be bothered now. Ive got an in-dash Kenwood TV and DVD instead.
Quick Spec:
1 GHz processor
20-gig laptop HDD Installed with XP Pro
128 Ram
DVD Rom (I think it’s a CD burner too)
I will put the full spec and Pics up later if anyone is interested. I don’t have a monitor for it though.
Ross
CASE
Morex Cubid 3688 Mini-ITX Case - Black
It measures 65mm(H) x 210mm(D) x 258mm(W) and runs very quietly.
Due to the small size of this case, you will not be able to fit a PCI card.
MOTHERBOARD
EPIA MINI-ITX VIA M10000
CPU: 1GHz VIA C3/EDEN EBGA Processor
Chipset:
VIA CLE266 North Bridge
VT8235 South Bridge
Memory: 1x184pin DIMM up 1GB DDR266
Expansion slot: 1x32 v2.2 PCI
Internal I/O Ports:
2 UltraDMA 133/100/66 IDE HD connector
1 FDD connector
2 USB 2.0 connectors
2 IEEE 1934 (Firewire) connectors
1 IrDA Infrared Connector
1 RS-232 serial port
1 Audio connectors (Mic/Line out)
1 CD Audio-in connector
1 Wake on LAN connector
1 Chassis intrusion connector
1 I2C connector
1 LVDS connector
3 Fan connectors
Rear External I/O Ports
1 PS2 Mouse ports
1 PS2 keyboard ports
1 Parallel port
1 RJ-45 Ethernet port
1 9 pin RS-232 serial port
2 USB 2.0 ports
1 VGA port
1 RCA port (TV our or SPDIF)
1 S-Video out port
3 Audio Jacks (line in, mic in, line out or 6-channel line out)
CD ROM
Sony CRX830 Slimline Combo CDRW/DVD
HARD DRIVE
Seagate Momentus 20gig 5400 rpm
RAM
128 RAM - Not sure of make, but will find out later.
Will get pics up later after work.
I think that’s about it. Let me know if you have any questions. It has got XP PRO already installed. I can keep that on, but I don’t have the License or CD :lcop: :up:
Looking for offers around £240.
Ross
1 - 9 of 9 Posts
