Fot that I would be pulling up carpets its thick!jonnaz said:whers the best place to hide some 0 guage wire?
Ive got 0g running down the passenger side and tbh theres plenty of room to hide it under the carpet, ive also got 3 sets rcas running down drivers side.muz said:Fot that I would be pulling up carpets its thick!jonnaz said:whers the best place to hide some 0 guage wire?
The difficult part would be the transition from cabin into boot however if you are willing to pull the car apart then you can take the back trims (If you have a 3 door) right off (You need to unbolt seatbelt scary stuff!)
It does fit as I have 3 sets of decent RCAs down the drivers side so it can be done
And strange plastic things that break really easily :-kMaddsy said:you will have loads of extra bolts etc what you can use for other jobs :wink: \/ \
