Will c what I can do Andy :wink:AndyK160 said:Gotta get one.........didn't come supplied (thats jonny for you :smile: )![]()
You probably haven't managed to clip it under the rear bracket mate when sliding it in, took me a couple of goes.Hincey said:half an hour to fit??? thats nothing! it took me an hour and 15!!! so much harder to fit it into a flippin bubble rover!! i nearly lost me handbrake!! was shitting my load!!! thought i had well n truely messed it up...wehn fittin the rear bracket, i cudnt line up the holes and it was impossible to do!! managed it in the end.......
is anybody else armrest wobbly????
yea i slipped it under the bracket, then took the cd tray out and screwed it in...but for some reason the screws do not fit into the holes at the front? they go through the armrest holes but not into the car holes...>>??Bech100 said:You probably haven't managed to clip it under the rear bracket mate when sliding it in, took me a couple of goes.Hincey said:half an hour to fit??? thats nothing! it took me an hour and 15!!! so much harder to fit it into a flippin bubble rover!! i nearly lost me handbrake!! was shitting my load!!! thought i had well n truely messed it up...wehn fittin the rear bracket, i cudnt line up the holes and it was impossible to do!! managed it in the end.......
As for fitting the other bracket. Make sure your hand brake is off. There is quite a lot of tension on the cable so i just jammed a screwdriver through the holes, and yanked it back, easy.
It litterally took me 10mins on my lunch hour to fit.
Mark
more to the point.........your handbrake aint on mate!!!tony-160vvc said:Where is the handbrake cover bit Andy?? :-k
You might need to take a bit off the front lip of the arm rest (the bit that goes under the front electric window switches).Hincey said:yea i slipped it under the bracket, then took the cd tray out and screwed it in...but for some reason the screws do not fit into the holes at the front? they go through the armrest holes but not into the car holes...>>??Bech100 said:You probably haven't managed to clip it under the rear bracket mate when sliding it in, took me a couple of goes.Hincey said:half an hour to fit??? thats nothing! it took me an hour and 15!!! so much harder to fit it into a flippin bubble rover!! i nearly lost me handbrake!! was shitting my load!!! thought i had well n truely messed it up...wehn fittin the rear bracket, i cudnt line up the holes and it was impossible to do!! managed it in the end.......
Mark
yeah i did...took off bout 1cm fits perfectly but holes dont line up...agghh! who sed it was simple...!The Grim Reaper said:You might need to take a bit off the front lip of the arm rest (the bit that goes under the front electric window switches).Hincey said:yea i slipped it under the bracket, then took the cd tray out and screwed it in...but for some reason the screws do not fit into the holes at the front? they go through the armrest holes but not into the car holes...>>??Bech100 said:You probably haven't managed to clip it under the rear bracket mate when sliding it in, took me a couple of goes.Hincey said:half an hour to fit??? thats nothing! it took me an hour and 15!!! so much harder to fit it into a flippin bubble rover!! i nearly lost me handbrake!! was shitting my load!!! thought i had well n truely messed it up...wehn fittin the rear bracket, i cudnt line up the holes and it was impossible to do!! managed it in the end.......
Mark
it took me a while to release the hand brake to take away the tensionAs for fitting the other bracket. Make sure your hand brake is off. There is quite a lot of tension on the cable
