1 - 7 of 7 Posts
how in gods name do i remove the window winders.. ive been at it all day and cant do it any one got a stupid persons way of explaining it cos i dont understand this book on how to do it... :hurt:
Pust the door card "Inwards" ......to expose the "Barrel" of the winder .......there's a Split pin that goes thru the winder & the shaft ..(It's bent over at one side ) straighten it out & pull it wiv a pair of needle nosed pliers !!!
Just thought....................yours could be different ..there's two diff ways they are attached
No1...............As I explained above
No2...............there is a "C" shaped clip that goes round the barrel ....to get this off you'll have to use a small screwdriver to "leaver" it off
Try an imagine the barrel goin thru the centre of the "C" you'l have to "Leaver" it off from here ...(>C) ..so the "ends" of the "C" open up ......
or spend 32 Zillion pounds on the "Rover" tool to do the job properly !!!!!!!!!!!!!!
1 - 7 of 7 Posts
