1 - 9 of 9 Posts
Right not sure what im meant to be asking for, but i wana upgrade my PC abit...
so whats the best graphics card??
and memory???? if that makes sense....and some links
seen some on ebay, but do you think they would be ok to buy from??
louise
Cheers peeps :up:
Lou, I would recomend that you find a person that knows thier computers cause it would be very easy to recomend things that maybe incompatable with the hardware that you have!
The last place to go is PC world.
it also depends on what u use ure comp for.
the mains things u should be thinking about is
Motherboard
Memory
cpu
graphic cards
again watch out when upgrading that u dont get ripped off and carefull what u upgrade to for example
new motherboard with faster bus speeds will require a good power supply 400w or up. what type of memory ull use (DDR) and what speed as the spped of the memory is more important than the capacity of it. also u got graphic cards is the motherboard got an 8xagp slot ?
if none of the above ring bells get some1 who knows anbout comps to help u.
I wouldnt go for the latest and greatest kit. Come down a notch and save big cash. The performance difference wont be anything to worry about.
1 - 9 of 9 Posts
