1 - 6 of 6 Posts
Hi Just found some steam comeing from around the turbo area.. i was driving along the other day and noticed it.. i later found out it is the ''TURBO RETURN PIPE'' Spoke to the bloke at the garage and he said its not that big of a deal however the pipe is rotting and needs replacing. theyve quoted me £80 for the job and obveosuly i would need to buy the pipe aswell. does anyone no were to get the pipe from? the engine is a rover 220 coupe turbo. and also if there is anyone from around the midlands area who can do it for cheaper let me know. ive been told theres a guy in nuneaton wich is just down the road from me.???? help!! lol
just go on the site and go on the turbo bit on the left hand side
found it mate. just rang moto build and they said i need the turbo water inlet pipe. its a thin black metal pipe wich bolts onto the turbo and feeds into a thicker rubber hose pipe.. they said they no longer supply this pipe and i would either have to cut the pipe down and extend the rubber hose or replace it if i could find a second hand one. but i cant cut the pipe down because its split right 2 close to the turbo. so i need to find a replacment?? any one have any contacts??
:unsure::unsure::unsure::unsure::unsure::unsure::unsure::unsure::sly:
1 - 6 of 6 Posts
