1 - 14 of 14 Posts
i drained the brake fluid and topped up with some fresh stuff but i've been pumping the brake for guts of 10 mins and i know from b4 the pedal tightens up, but this time it tightens and then drops again. is there air lock? is it just matter of unscrewing the bleeding screw? does the brake pedal need to be down while this is been done? would appreciate help as i have to leave my bro to work first thing in the morning and its now 11 :S
thanks , Sean
get someone to put there foot on the brake pedal ,you undo the bleed screw tell them to press down slowly ,when they reach the floor ,you do up the bleed screw ,and they lift foot of brake pedal (repeate process 3-4 times until all of the air has has come out (keep topping up brake fluide theo by the way ) job done
Test them by driving down a big hill at 90mph+ ?
1 - 14 of 14 Posts
