there have been some posts on here about this but nothing concrete - please could someone tell me the best way of fitting replacement door speakers and then stuffing the doors so that they do not vibrate - and what is the cheap but best option? The doors vibrate just by having the new fronts running off the HU. =;
So far I've got about £600 worth of Audio Equipment fitted / in need of fitting - but I'm struggling to get rid of the poxy rattles from the doors! ](*,)
I fitted the fronts on the outside of the door panel - I pulled the grills off, and screwed in the speaker on the grill - the next plan is to make something from MDF probably which will sit behind the door panel and fill the space to the metal, then the speaker screwed into this for more stability - I quickly installed them, they look good but rattle as the only thing holding them in the plastic door panel!
has anyone found a quick, cheap, easy solution to stuff the panels to stop them rattling? I don't want to spend a fortune on this - but I need to do it as I'm probably amping them next weekend when my new amp arrives. \
cheers guys
Luke
cheers guys
Luke
