1 - 6 of 6 Posts
i have a 05 1.4 zr and understand it has the IB5 gearbox (ford) i have noticed my selector has been getting play in it and i have owned numerous xr3i's and rs turbo's which also had the same IB5 gearbox and that was a common fault on them. to remedy that fault a new bush was required for the selector. now the point i am trying to get across is does the zr share the same slectors as ford's? if so there must be ploy bushes available for them?
i dont know if they share the same ones as fords, but there are definitely poly bushes for them, i've just ordered some powerflex ones :)
i was under the impression that poly bushes were only available for the pg1 gearbox? if you did order some where did you get them?
ah sorry, i was assuming the linkage was the same for both boxes, mine is a pg1. if the linkage is different then i dont think they do them, as they dont list any others than the ones i've ordered, unless as you said the ford ones are the same.
1 - 6 of 6 Posts
