1 - 12 of 12 Posts
Have you checked fuses?
When one side of my sidelights stopped working this was the case
Might not be the problem because i dont have a clue either lol but its just similar to what went work with mine.
In the drivers footwell on the back of the fuse box cover is a diagram of what all the fuses are for. Find the one for the fullbeam lights, pull it out and see if its burnt out.
Like this
It is to do with the earth to the sidelight iirc, take the cap off that you use to access the main beam bulb and make sure the sidelight is connected properly and works correctly.
I had this about 7 years ago, so if it sounds a bit vague.
Let me know if this helps, if it doesn't I'll have another look tomorrow when I have a car in front of me
Dirty user
May be a fuse but they are sided.
Fuses left colum is the fuse number the other numbers are the amp
1. 10 Indicators, instruments
2. 10 Anti-lock brakes
3. 10 Clock, radio, interior light
4. 15 Headlight - right, main
5. 15 Headlight - left, main
6. 30 Sunroof
7. 5 Airbag SRS
8. 10 Tail lights - left, headlight height - left
9. 10 Rear fog guard lights
10. 10 Headlight - left, dipped
11. 10 Headlight - right, dipped
12. 15 Tail lights - right, headlight height - right
13. 15 Wash/wipe - front
14. 10 Engine management
15. 15 Cooling fan, wash/wipe - rear
16. 10 Reverse, stop lights
17. 10 Radio, clock
18. 10 Door mirrors, air blowers
19. 10 Cooling fan, front fog lights
20. 10 Engine
21. 20 Window - driver
22. 20 Window - passenger
23. 25 Rear screen demister
:D
Whoo i could be right about something car related :mml:
I have a similar problem although it's with my reverse lights. I have changed the bulbs and still no good. I notice from the earlier post that the same fuse relates to both the stop lights and reverse lights. my stop lights are working fine so i guess I have a different problem, any ideas?
Dirty user
Possible gearbox switch or a break in the loom.
1 - 12 of 12 Posts
