1 - 14 of 14 Posts
Fake Bans FTW!!!
how do you change a fuel filter?
it says online that i need to dissconnect the fuel pump fuse or relay but where are they?
You don't.
IIRC the fuel filter is on the bulkhead on a 200 the same as a ZR, You just need to undo the two connections and replace
changed mine a couple of weeks ago disconnected battery for safety`s sake but thats it just uncouple the pipes top and bottom check flow arrow dosen`t work wrong way as one of my mates found out on his! make sure you got plenty of rags under or half a 2 liter bottle cos it holds more fuel than you think.
mg zr rally car
why do you need to disconnect the battery? theres no plugs on it? and you wont get an elcetric shock off it
Fake Bans FTW!!!
Fake Bans FTW!!!
Fake Bans FTW!!!
Discussion Starter · #10 ·
Saying that it will still spark if disconnected :rofl:
Fook im tired :D
lol i **** myself changing it after reading this "if you dont relise the preasure of the fuel system before removing the fuel filter it may cause an explosion" :eek:
Dirty user
lol
At least it all went well....
Iv'e done loads with no problems (as yet) :bounce:
disconection of a power source is just safe workin practice safe not sorry is always good workin policy only takes one spark especially with fuel which is highly flammable and so is its vapour even when the engine is of there are loads of wires carryin power all of which are perfectly capable of bein bared and at risk of stray arc`s with the battery uncoupled these wires are not live so far less risk!
1 - 14 of 14 Posts
