1 - 9 of 9 Posts
my right and left front indactor have water in them and now the right one dont work, and the other week the left one didnt work then alov a sudden started to work again o_O
think u solved ure own problem if u got water leak it will turn to vapour when the indicators are on then when they are off they will cause dampness on the bulbs giving u intermitent problems.
^^ i think
i went to the dealer once before and i dont think they even looked at this problem, ill have to go again!
just pop them out remove the bulb holder and shake the water out...then put them on the rad in the house to dry out.......
Check your handbook, under "changing bulbs". I got a 105+ and just prised off the plinth (very easy) which gave access to the screws which lets you pop them out.
I have a small condensation problem in nearside indicator which I still aint cured, as it still happens. But taking it out (as above) and drying on a rad does help.
1 - 9 of 9 Posts
