1 - 13 of 13 Posts
Firstly apologies cos i know for a fact this will be somewhere just not found it.
My front brake pads are needing replaced on my 105 MK2.
I would have prob gone for greens tuff but since there has been a couple or posts around saying that they fall apart im not to keen naturally.
I notice alot of you guys suggesting or are using mintex pads. Are these my best option also bearing in mind my disks are the standard ones will i need to replace these at the same time?
Relitively simple question i would imagine for some of you guys im just no sure lol too many choices ha ha :trampoli:
Cheers in advance.
Dirty user
Mintex ftw
Knock spots off my old greenstuff tbh :)
You will onlty need to replace the disks if they are fooked or you want to upgrade :)
Mintex ftw
nice one much we looking at for a set of the bad boys? just pads that is?
Im hoping its just disks makes a kinda rubbing/grinding noise at the offside front when im driving and then stops when i press the brake pedal :wacko:
Obv gonna get it checked out but just seeing what i should get if it turns out to be pads which i hope it is lol
Dirty user
If the pads are down to the metal the discs could well be fooked..Or it's just the pad low warning indicator..
I paid around a tenner for mine that was trade still running the ebc discs thou :)
Cool..Cheers for the info mate.
Go on holiday a week on sat so was really hoping they would hold up till then and i would get em sorted when i came back but it dont look like working out that :wall:
Acht well best no F^^k about when it comes to brakes i suppose ha ha
Just got a cost from a local garage for supply and fit of mintex pads for front end.
£65 Fitted :S
Good? Bad? Or Indiffent? No an expert on brakes never had to put a set on a car before lol :blush:
About Right, 1/2 hour job £20 ish, Pads £20ish + VAT
Cheers mate...they are just round the road from my work so easy just to drop it in on the moning and pick it up at night..go on hols a week on sat so was hoping they would hold up starting to grind like fook tho lol
1 - 13 of 13 Posts
