Status
Not open for further replies.
1 - 1 of 1 Posts
Tools Required
• 15mm Socket
• 14mm Socket
• 13mm Socket
• 22mm Spanner
• 10mm Spanner or Brake Pipe Spanner
• Pliers
• 2x Short M6 Bolts & Plenty of Washers
• Goodridge Hose Set SMG1600-4P
Front Hoses
• Open Brake Fluid Reservoir
• Remove Banjo Nut and allow Fluid to Drain
• Loosen Brake Pipe Compression Fitting
• Remove Clip holding hose in place with pliers
• Remove brake line mount
• Attach new brake line to pipe – first use clip to retain hose in place, then hold the goodridge nut with a spanner and tighten the brake pipe compression fitting
• Use original brake line securing nut to secure the new hose as it was originally
• Using the new copper washers provided, place one either side of the hose banjo and re-attach to the calliper, and tighten securely.
• Check the hose isn’t fouling on the suspension or wheel, adjust hose position if necessary.
Rear Hoses
• Attatch new brake line to pipe – first use clip to retain hose in place, then hold the goodridge nut with a spanner and tighten the brake pipe compression fitting
• Use the M6 bolt to secure the new hose in a similar position as it was originally in the threaded section on the subframe.
ALWAYS BLEED THE BRAKES AFTER FITTING NEW HOSES!
1 - 1 of 1 Posts
Status
