1 - 8 of 8 Posts
Discussion Starter #1
Does anyone know of or have any experience in connecting your ECU into an incar PC, to view stuff that the ECU spits out ?
Discussion Starter #3
i found some software on the net at work, ill post the link tommorrow, but surely it shouldnt cause any probs if its just reading it ?
what do you want to see from it? you'll have exactly what it'll show infront of you anyway :-k Revs, speed and temperature. Probably your idle status as well.
As a newbie to the forum i thoiught i'd tell you about this piece of kit
http://www.auterraweb.com/
It is US based software and works fine with any OBD2 compliant car. It is also used on a pocket palm so you can plug into the OBD2 socket and read the sensor values whilst driving
It also reads and clears fault codes so all in all not a bad bit of kit
Yeah, you can do this easily.
I have all the links at home in my favourites. Ill dig them out and post them
Basically, it is a case of getting a cable, plugging into the ECU port then to your PC.
Thats it!
Mark
1 - 8 of 8 Posts
