1 - 12 of 12 Posts
The light on my dashboard clock has suddenly decided not to work?
Any suggestions please on what it might be? :?
bulb?
Fuse?
(presuming that the LCD display is still working and it is just the back illumination that has packed up?)
Sleeping
i dont think it would b the fuse, as that fuse is linked to sterio, inside light and rear light. i found that out last night when i sorted the boot light and lost everything, mad dash to halfords for the fuses!!!
mine aint working now n its done it both zrs ive had.
is there an easy way 2 change this - i cant find a how to guide.....
Formerly Trophynovabasher
mine was out when i got it a yr ago, but cant be bothered to fix it, but its just the bulb, remove the cover and the clock face and the bulb is behind, i believe they are readily available in halfrauds.
10 min job to do.First remove the plastic surround from the clock(a blunt knife with a piece of cloth covering to stop scratches etc).A small cross head screw driver to remove the 2 mounting screws(this is the worst bit if you drop the screw it will go down the back of the dash) a magnetic driver is best that's what i used.
Pull the clock towards you(no ned to disconnect the power cable)& at the back of the clock you will see the bulb holder turn to remove replace bulb & do the reverse to re-fit.Very easy job it's the same to fit the traffic master alert system if you find one.
1 - 12 of 12 Posts
