1 - 5 of 5 Posts
Discussion Starter #1
Car won't start it turns over and everything else works fine, it just seems there's no petrol getting through. Any ideas would be greatly appreciated
Could be loads of different things such as crankshaft sensor, fuel pump, snapped cambelt unfortunately will need bit of looking into/diagnostics to pin point the exact fault
If there's no fuel getting to injectors is the fuel pump working? If not check it has a +12volt supply and Earth while cracking the engine over. If it does and the pump is working check the fuel filter isn't blocked
1 - 5 of 5 Posts
