1 - 4 of 4 Posts
mg zr rally car
am fitting a set of gaz coilovers to my mates zed soon. and i want a ruff idea whats the best mm to lower it by? im thinking about 40mm. how many threads ruffly is that up?
Rover Owner
I'm not sure that your question has an answer mate. It's hard to say how much i have lowered mine by on the KW V2s, maybe 50mm. I have got it sitting so the arch gap is pretty much consistant all around the wheel, so about 1.5 fingers at the top of the wheel.
how many threads up from where? the bottom thread? when you fit the coilies, you will have to set them all faily high, then lower to the required height. You do not just fit them and they make the car standard height, then you lower.
1 - 4 of 4 Posts
