im using the original air box feed (behind the headlight) as the air feed that came with the filter is huge!!!! no place to feed it down to the floor ](*,)ZR__Lincs said:wheres the cold feed routed?
so you have used the telescopic corregated tube to link between the filter and the original cold air feed? Did you take the bottom half of the air box out?muldersZR said:im using the original air box feed (behind the headlight) as the air feed that came with the filter is huge!!!! no place to feed it down to the floor ](*,)ZR__Lincs said:wheres the cold feed routed?
yes mate ive removed the box............this filter is huge.........hence why its at an angle, wouldnt fit with anything there..........and used a heat resistant feed between the filter mouth and the original feedZR__Lincs said:so you have used the telescopic corregated tube to link between the filter and the original cold air feed? Did you take the bottom half of the air box out?muldersZR said:im using the original air box feed (behind the headlight) as the air feed that came with the filter is huge!!!! no place to feed it down to the floor ](*,)ZR__Lincs said:wheres the cold feed routed?
