1 - 12 of 12 Posts
I have a REALLY annoying vibration in the rear driverside door card (I think) when the bass kicks in. Its not port noise from the sub, I think it might the seatbelt mech vibrating against the inside of the door panel but I cant be sure.
Its embaresing cos from the outside all u can hear is a gay vibration noise!!
Help? Solutions?
dynamat the car i did that with mine and you cant hear a thing outside the car :D but inside ohhhhhhhhhhhhhhhhhhhhhhhhhhh she booms now :D
just take the door cards off and pop in it? that easy?
How many square feets do I need?
Depends how much you wanna cover :up:
Behind all the door panels?
R6 Owner
Right :jib: get a tape measure out
Measure it
add a bit
buy it
fit it
Job done :up:
cheers for that maddsy, would never have thought of it ;-)
:hiding:
Discussion Starter · #10 ·
id like to know that too, cos i'll prob destroy my car if i try and do it lol.
To fully properly sound deadon your car
1 Use brown bread, its cheaper than dynamat and at least as good
You will need 2 sheets per door, a trunk kit for the boot and 4 sheets for the floor under the carpet
Total cost around £300 plus fitting (£20 per sheet, £140 ish for the trunk kit plus a can of spray for those hard to reah places)
My ZR had 2 sheets in each door but there were still some rattles!
Oh yeah nad it will take a good day to fit! you need to take the entire interior out of the car
However it will make your system twice as loud and cut out all the road noise plus your doors make a nice noise when you close it
1 - 12 of 12 Posts
