1 - 4 of 4 Posts
ok gonna b fast with this one so if i cant fix it fast and for free then tis goin back on ebay
got a 1600 amp 2 replace my 800w fited it green light somes on an every thing so theress no pwoer problems or anything but i dosnt do anything no sound coems from the amp so iv just put my 800w back on and works fine sub works fine its ok so what could b the problem #-o
if ure using the same wiring to power the 800w amp and everything is fine then the only thing it can be is the gain setting, or the filter settings
turn the gain up to just above half, and make sure ure band pass filters arent turned down far to low
apart from that sounds like its a rip amp look for over protection lights, or low voltage lights i
if tihe old amps working ok and you have tryed add the gains etc then there must be a prob with the amp.......
1 - 4 of 4 Posts
