I could technically have two if i wanted to.
Dont know if everyone`s Zed is the same as my 105 but if your standing at the front bumper looking directly at it- Lift the boonet up and look to the left of the radiator (drivers side basically).
On mine as the radiator ends there a black plastic cover thing that runs the height of the radiator and two clips which hang over the side of the radiator.
I took this cover thing off. (not the easiest i tell you) and cut a hole in it the same diameter of the cold air feed if you know what i mean and ran it through that hole and towards the front grill.
I could cut the mesh on the front bumper and put the end of the cold air feed through if i want to like you say above but didnt want to go down this route. Dont know how effective this route is right enough, but at the end of the day it is only a piperx open filter on a 1.4 so not expecting miracles.
Here, Donna im home in 10 days or so, if you want me to give you a shout and show you what i mean.?
