1 - 5 of 5 Posts
Hi currently fitting my sub and amp. And need to remove the rear seats so I have access to pull the rear quarter panels off.
How do I remove the back seats from the 3 door zr? Please help! thank you.
pull up back boot carpet, there are 4 bolts when the seats 60/40 split. and then 2 pins either side of the seats, wiggle them and the back will come off. for the lower part of the seats they are on bolts and hinge/hooks, be careful of seatbelt pretentioner brains is under there! oh and you'll need a half decent socket set :)
adam
Look in the boot, you will see a triangle shaped bracket.
There is a 10mm bolt in the back of it, unscrew this until the latch appears open, fold the seat in the normal way, and lift upwards.
Dave
1 - 5 of 5 Posts
