1 - 2 of 2 Posts
Again the missus car.engine has been a pain in the arse from day one.
Struggles to start unless you press accelarator then it starts and runs fine.
Isnt using oil and isnt using water.
Although there is mayo sludge in the water bottle,but not under the oil cap!
sounds like ur head has gone but not the part into the oilways, only the coolant ones, so you'll could be leaking coolant into the cylinders and air fuel mix into the coolant. could be wrong obviously....are you getting any steam out of the exhaust, and are you SURE its not using any water?
1 - 2 of 2 Posts
